transfer case..full
1994 s10 blazer 4 door. 4.3l engine
I was checking the trans fluid in the transfer case and i opened the top plug to check. ATF flowed out of it . over full. I checked the tranny and I had to add a quart. If the front input seal is bad and the extra atf came from the tranny, what troubles can happen if it keep the tranny full of atf and leave the transfer case as is? |
Eventually atf will be pulled into the vacuum system resulting in an even bigger mess. I would drop the t-case and replace the faulty input seal.
i dont necessary know if it will cause damage to the transfercase. but my truck did the same thing. my rear output seal started leaking so i figured ok ill change it. pulled the driveshaft off and out leaked like 1-2 qts of fluid.
if you want to put it off you can just monitor the transmission fluid and drain the transfercase as necessary |
Transfer case overfull
I have the same problem, transmission low and transfer case overfull. 1998 4D 4x4 Blazer
Are there two seals to change? Input on Transfer case and Output on transmission? How heavy is the transfer case? As I understand the process: 1) Remove skid pan 2) Remove rear axel 3) Remove front axel 4) Drain Transfer Case 5) Remove bolts and remove transfer case, Does the shaft support this or does it fall when the bolts are removed? 6) Remove rear transmission shaft (not sure about this) 7) Replace rear transmission seal 8) Reverse steps Thanks for your help! |
Originally Posted by mswillia1
(Post 489184)
Are there two seals to change? Input on Transfer case and Output on transmission? How heavy is the transfer case? As I understand the process: 1) Remove skid pan 2) Remove rear driveshaft 3) Remove front driveshaft 4) Drain Transfer Case 5) Remove bolts and remove transfer case, Does the shaft support this or does it fall when the bolts are removed? 6) Remove rear transmission shaft (not sure about this) 7) Replace rear transmission seal 8) Reverse steps Thanks for your help! The transfer case is held to the transmission adapter by six 15mm nuts. Here's a video that goes through the process. It's on a suburban with the NP246 transfer case, but the s-series is similar. Remove/Replace/Rebuild GM 246 transfer case, 2000 Chev Suburban - YouTube |
| All times are GMT -5. The time now is 07:30 AM. |
