turning left the front end noise stops
Old 02-20-2009, 04:27 PM
stark05's Avatar
stark05 is an unknown quantity at this point
Default turning left the front end noise stops
When I turn to the left the noise and vibration stops, when I go forward and take rights the front end makes noise and grinds, (I notice it more when above 20 mph). Itsnot really bad but needs to be fixed. The right front wheel bearing is new. any idea, thanks
Old 02-20-2009, 04:31 PM
lene 98 is an unknown quantity at this point
Default RE: turning left the front end noise stops
what kind of noise
Old 02-20-2009, 06:11 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
That actually sounds like a LEFT front wheel bearing, if the noise quits when you turn left.
Old 02-20-2009, 06:19 PM
ORIGINAL: lastcoupe
Yep, my thoughts as well.
Old 02-21-2009, 09:39 AM
stark05's Avatar
Thanks, I guess I will do the other side now. kinda spendy but needs to be fixed.
Old 02-21-2009, 09:42 AM
stark05's Avatar
its a vibrating/grinding noise. consistant with a wheel baring noise, I was told when I bought the truck the right front bearing was bad, I replaced it and the noise changed so I guess both wheel barings may have been bad. The truck had alot of highway miles, its got 91,000 on it now.
Old 02-21-2009, 09:49 AM
stark05's Avatar
the slightest left turn and the sound go's away. if I'm on the highway and I change lanes twards the left the sound stops for the time i'm changing twards the left. Still sound like the left bearing?
Stark05
Old 02-21-2009, 10:13 AM
bandidolenny's Avatar
Only 91k miles anda frontwheel bearing went out? Pull the tire and caliper off and spin it by hand so that you can "feel" the bearing spin. Were they submerged or Something? If theright sidewas out then the other side cant be far behind.
Old 02-21-2009, 10:20 AM
stark05's Avatar
Thanks
Old 02-21-2009, 11:20 AM
lastcoupe's Avatar
ORIGINAL: stark05
Stark05
Definitely....
Quick Reply: turning left the front end noise stops
