Upper Control Arm Bump Stop
Does anyone know where I can obtain upper control arm bump stops? I replaced my arms and the ones from my old arms aren't any good
Dealer, though you might want to use some rear bump stops from a mid 00's Chevy/GMC half ton instead. I don't have the part number off hand, though. Rather than an abrupt "stop", the truck rear bumps ease into it. I installed some about a year ago and like them much better in off road conditions.
I'll look into it. The control arms right now just sit on the frame when I lift it up to work on it. Not to mention the bump stops on the frame are shot as well.
order some energy suspension urithane bumpstops. ive orderd some today as when im at full drop offroading my cvs bind up and will cause premature failure or snap a axle on the trail. i also got some for the bottom as well so i dont bottom the truck out from the lift and shove the wheel all the way into the fender well
autozone,advance or most any other autoparts store...
These are Bitch'n!
1996-1999 Chevrolet Blazer Control Arm Stop Dorman, Front, Lower, OE replacement 2nd choice: http://www.summitracing.com/parts/mog-k6606 |
| All times are GMT -5. The time now is 09:16 AM. |
