Community
Search
vibration 60-70mph
Old 07-15-2010, 07:27 PM
nats1956 is an unknown quantity at this point
Default vibration 60-70mph
Been having a vibration that has been plaguing me for the two year. Vibration starts around 60 mph and starts to smooth out after 75 mph. I've replaced all the ball joint/tie-rod/pitman and idler arm. Installed upper and lower control arm bushings. Replaced the sway bar end links. Had new bilsteins installed all around-had the driveshaft balanced and all u-joints replaced. Got new rubber all around and had them balanced several times and had the front end aligned 2-3 times in the last 6 months. I feel the vibration in the steering wheel.
Old 07-15-2010, 08:48 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
what veh is it your asking about? did you have the alignment done after all that front end work? Did you check the front hub bearings for any play? were the tires properly balanced?
Old 07-15-2010, 09:02 PM
jbsnowboarder16 is on a distinguished road
This may help and it may not. I had the same problem with my 00, but it went away after I got brand new tires, maybe something out of balance
Old 07-17-2010, 06:56 PM
blazerboy001's Avatar
blazerboy001 is on a distinguished road
It may be because the belts on the inside of the tires may be coming apart. That's what is happening on mine. My truck is lowered and at full lock the wheels will rub. That's what causes mine. It would help if we knew what kind of truck you were driving.
Old 07-20-2010, 05:07 PM
mikekolb is on a distinguished road
Sounds like tires to me... I am in agreement with the above, obviously
Old 07-20-2010, 07:21 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
i would get the tires balanced on a road force balancer. and then get a alignment.
Old 07-22-2010, 04:30 PM
Default vibration
Alignment was done several times from two different places-tires are brand new and had them balances and rotated.
Old 07-22-2010, 04:35 PM
GeeRacing18 is on a distinguished road
I have the same thing its a pitmen or idler arm
Old 07-25-2010, 03:06 PM
I replaced all of the front end parts-pitman ,idler arm, upper lower ball joint,tie rod ends on both ends( parts from synergy) and installed new moog upper/lower control arm bushings. New bilstein shocks all around. Had the driveshaft balanced and new u-joints. Bought new tires and had them forced balanced and the front end has been aligned. This is driving me crazy! Could I have a bad hub/wheel bearing or axle?
Old 07-26-2010, 05:59 AM
wGraves is an unknown quantity at this point
To me it sounds like the front hub bearings. Mine was doing the same thing and I did just about everything you did and when I replaced the front hub bearings it went away.
Quick Reply: vibration 60-70mph
