What's this noise?
Old Mar 1, 2015 | 06:36 AM
Doug Rogers's Avatar
Doug Rogers is on a distinguished road
Default What's this noise?
I have a 1996 Chevy Blazer 4x4 4.3 liter V6. I took it to Monro Muffler where they did an alignment lower ball joints on both sides in the front wheel bearing and wheel hub on the passenger side and an alignment and a new pitman arm. When they were done they told me that the brakes needed replaced as well. About 2 hours after I picked it up I noticed a high pitched whining noise coming from somewhere in the front of the vehicle ads in the suspension system or in the steering system somehow. I thought that it was brake noise so I put all new brake pads and new calipers on the front the rotors didn't need changed. It still makes this noise and I can't figure it out. Here is a link to a video I made trying to diagnose this noise. Thank you very much in advance.
What's this noise?: http://youtu.be/-oqc2ND_mIA
Old Mar 1, 2015 | 07:29 AM
newguy's Avatar
They may have over tightened the hub nut, But it definitely has to do with rotation of the wheel. There is a torque spec for the hub nut and if its to tight it wont last long. Does it go away when you brake?
Old Mar 1, 2015 | 08:28 AM
No, it only seems to do it when I'm moving slow like going through drive thru or something. When I hit the brakes it still does it.
Old Mar 1, 2015 | 08:29 AM
they put the new wheel bearing and hub on the passenger side but the noise sounds like it's coming from the driver side. The only thing they did over there was the lower ball joint on the driver side.
Old Mar 1, 2015 | 11:22 AM
newguy's Avatar
hmm, possibly just needs a bit before the brakes break in. Or somehow the wheel hub is going bad on that side
Old Mar 1, 2015 | 06:04 PM
dharvey4651's Avatar
dharvey4651 is on a distinguished road
Sounds like a rotor backing plate rubbing on the rotor.
Old Mar 1, 2015 | 06:17 PM
newguy's Avatar
Ha, good call, never thought of that!
Irish07
Oct 31, 2012 06:04 PM
Chrismacster
Apr 2, 2009 06:57 PM
