Wheel/Rim spacers, are they okay?
Hi guys,
I wondered if anybody used wheel spacers/adapters on their ZR2 to change how much the tires stick out? I have an ’01 Blazer ZR2 and noticed that the back wheels are about an inch back inside the wheel well, while the front wheels stick out a little bit more at about 3/16’’ out of the wheel well. I wanted to match the rears to the front and if I put say a 1 inch spacer on each back wheel they would stick out almost exactly like the fronts do. Basically, I just don’t really like it how the back axle looks so narrow and does not match the front. This post is NOT about whether somebody thinks this will look good or bad. I am not looking for a debate on that. I just wanted to know if they are safe and okay as I’ve never used them. The ones I saw are an inch thick, have holes to be bolted to the hub just like any rim would be, and then there are 5 studs sticking out to bolt your wheel to. Anybody’s experiences or knowledge on this would be appreciated! John |
I've got 1.25" spacers on the rear and haven't had any problems. This includes daily driving, road trips and offroad. There are a couple of pics in my photo album that might show you how it looks with the spacers.
Long term they can lead to axle damage as there's more stress on the axle/components. All S10s (and the SUV/GMC variants) have a narrower rear track. I would say 1/2" or less spacer is probably OK, but any more than that and you're asking for trouble. On the other hand, there are some who have a 3" Tbar crank with no problems. Doesn't mean it'll work without issues for most. :)
I have never heard of spacers on a rear STRAIGHT axle causing any type of axle damage, let alone components as there are none. I'll agree with them might causing undo stress on the front end of an IFS, much the same as running wheels with too little backspacing.
You should not have any problem as long as you buy quality ones. I used to sell them.:icon_bike:
Originally Posted by AJBert
(Post 265489)
Originally Posted by Monkeyman
(Post 265533)
You've never heard of a straight axle bending or all the bearings, etc?
I am truly having a hard time understanding your logic on this matter. |
(Post 265544)
(Post 265664)
I have no doubt. Do some research and you'll end up agreeing with me.
Apparently, you have your opinion and I have mine. I've seen what an inch or two can do. These trucks aren't the strongest in the world but anyone is free to do what they wish with their truck. I won't use them but I don't care if other do. :)
HAGO |
| All times are GMT -5. The time now is 08:36 PM. |
