ZR2 Blazer vs regular Blazer rear spring
Old 08-28-2018, 07:13 PM
gman4q2's Avatar
gman4q2 is on a distinguished road
Default ZR2 Blazer vs regular Blazer rear spring
OK, I recently purchased a 2003 Blazer ZR2 and it has the usual rear spring sag. I've searched high and low on the the forum but cant find an answer to the question of spring difference between the regular Blazer and the ZR2.. The specs (dimensions) seem to be the same, according to the diagrams on General springs website. Are they interchangeable? If so, will the increased weight capacity (1300lb vs 1100) equal an increase in height?
Thanks for the info.
Old 08-28-2018, 07:32 PM
chevyriders's Avatar
Here you go
Old 08-28-2018, 08:09 PM
gman4q2's Avatar
Thanks, but I only see an S10 ZR2, and no Blazer ZR2.
Old 08-29-2018, 05:00 AM
Oops, I thought it had blazer zr2 on there too. Sorry!
Old 09-18-2018, 01:14 PM
man0steel's Avatar
man0steel is on a distinguished road
This spring has one standard eye and the other eye is kind of strange as it’s called a reverse dutch so it’s not completely reversed as it’s reversed and then taken back to mid eye.
https://www.generalspringkc.com/product_p/22-1333.htm
Old 09-19-2018, 12:04 PM
gman4q2's Avatar
I've seen what my ZR2 springs look like with the reverse dutch thing, but all of the springs on this website look the same, the only difference is the # of leafs in the pack. Is there a different arch height between the two? Are the shackle bolts the same diameter?
Old 09-20-2018, 11:45 AM
man0steel's Avatar
It's a default pic with specs, they were a perfect fit for my ZR2. I was sagging in back by 3 inches, you can see the stance on my avatar with the new springs.
Old 09-27-2018, 12:31 AM
gman4q2's Avatar
Did you replace them with the ZR2 springs or regular Blazer springs? I would like to go up a little in weight, possibly to the 1300lb rate.
Old 10-07-2018, 09:14 AM
man0steel's Avatar
I replaced mine with the springs in the above link for ZR2. I don't know if any others would fit and function properly, that being said I am sure someone has done it before thinking correct springs were not available (it took me quit some time to find the right ones). You might also consider what a heavier spring rate might do to the ride, I would think it would be very rough.
Old 10-22-2018, 12:15 AM
gman4q2's Avatar
I replaced mine with the springs in the above link for ZR2. I don't know if any others would fit and function properly.
That is my question, will the others fit, what is the difference between the applications? I too would have thought someone would have tried the regular springs on a ZR or vice versa, or maybe somehow been sent the wrong springs and found out they didn't fit which would also answer the question.
Grifs
04-02-2022 07:58 PM
schaffer1984
Suspension Tech
05-25-2013 08:51 PM
Logan
36
12-06-2009 07:41 PM
blazer/gtoman
02-26-2008 04:15 AM
komodopb
23
06-14-2007 03:23 PM
Quick Reply: ZR2 Blazer vs regular Blazer rear spring
