4wd turned dragster
Has anyone seen a 4wd blazer turned dragster?
I was wondering what to do with my blazer, thinking maybe along the lines of a Typhoon style 4wd or 2wd with 4 doors. Probably use a 350 v8/th350 or a turbo v6. I traded in my Corvette on a new body Silverado 4wd so I don't need a 4wd really I would like something fast as I miss my Vette and I don't know how long it will be until I can buy another Vette. Yes I will be doing all the work myself except the block cleaning/honing on the 4 bolt main 350 block I got. Are there any builds out there I haven't seen |
so your plain is to build something that you can take to the track and abuse pretty much am i correct?
Abuse, definitely, I already have a daily driver Silverado, just need something to play around with, ala Blazer dragster
Obviously a four door 4wd is not the best model to start with but its what I got Looking for builds or videos if anyone has any links, thanks a lot |
be better if it was AWD :] then so many more doors open to do stuff with
Actually it has autotrack AWD option (4 button) switch.
I have had this blazer for so long, longer than anything else, ever, car wise and I don't think I can get rid of it so I want to find something else to do with it besides let it sit in garage (unless daughter is driving it):icon_banana: |
Have a look through the builds and find GregW's TYCLONE. Its a vette V8 AWD. You will like it alot. I love my new silverado. Have a look at it in the builds section too its called SOSOFLY. I wouldnt mine seeing what wheels you chose for yours.
~$500 convert it to awd with used parts from astro should all bolt up other then front drive shaft I think, need to be lengthened?
Would love to see a turboed 350 awd blazer with 400-600hp. Upgrade the suspension for better handling and you got a very nice sleeper that you can still use as a suv. |
A guy my dad works with shoved a 584 (horse to the wheels) ls1 in a second gen 4 door 4x4. He would do 4x4 launches against civics and still have wheel Spin like crazy
i saw a Jeep on that show Pinks! one time that had a 6.71 blower on it and was 4wd. ran a pretty good 1/4 mile i guess. its been awhile since i saw it. but he did do a 4 wheel burn out which was pretty BA.
Have you done this? that seems pretty affordable. local junk yard has tons of astros. id be interested in seeing this Karcinagin, sorry i wasnt trying to steal your post, this is my first forum and im still learning... [QUOTE=pio;649391]~$500 convert it to awd with used parts from astro should all bolt up other then front drive shaft I think, need to be lengthened?[quote] sorry |
| All times are GMT -5. The time now is 12:47 AM. |
