-   Street N Strip (https://blazerforum.com/forum/street-n-strip-26/)
-   -   gears (https://blazerforum.com/forum/street-n-strip-26/gears-9368/)
5.7Lblazer 03-15-2007 09:04 PM
gears
im wondering what gears i should get i have a 350 in a 85 S10 blazer and i am setting it up for drag
im looking at 373 gears any suggestions on the gears and any other ways i can add power
drperry 03-15-2007 09:21 PM
RE: gears
3.73s or 4.10s will work great for ya... a 350 is a lot of power in a light truck... even with 3.42s or 3.08s you'd be pretty damned quick
5.7Lblazer 03-15-2007 10:03 PM
RE: gears
yah that is what im aiming for outrageous power havent seen any S10 blazers set up for drag around here in Warner robins, GA
5.7Lblazer 03-15-2007 10:12 PM
RE: gears
were is the best place to get them from summit is the only place that comes to mind
drperry 03-15-2007 10:16 PM
RE: gears
jcwhitney, maybe or gmpartsdirect or gmperformanceparts...
5.7Lblazer 03-15-2007 10:20 PM
RE: gears
ight im ready to get them gears but i need a paint job bad that is prolly what im getting this month and headers and gears next month
bigjsp 03-15-2007 10:48 PM
RE: gears
I'm running 4.10s with a 4L60E tranny and 3000 stall lock up convertor with an LS1 motor
still get 22 MPG and the first gear is much better than when I had 3.42s. although I used to get 24 MPG.
I have had limited success with GM rears, although other peoples run them just fine. Something to consider before spending money on gears and getting them set up, look around for a factory rear with the gears you want.
You can also play temporarily with the tire size, mount some 24 inch vs 27. That is essentially a 10% gear change just like going from 3.4 to 3.70's approx
5.7Lblazer 03-15-2007 10:52 PM
RE: gears
ight thanx for the advice guys
