TWIN TURBO
I have hear there is a twin turbo kit for my 2002 blazer is this true and where will i be able to find this at?
Thanks The Troll |
RE: TWIN TURBO
you might wanna post this in forced induction. But anyways i havent ever heard of a twin turbo kit... Machperformance.com makes a single turbo, turbo kit that runs supposedly 13.1 in the 1/4 which is darn fast. But there are mixed feelings about there turbo kit, i think a supercharger is the way to go unless you make a custom turbo kit like a STS one or something. Put the turbo after the header. A guy on s10forum.com made one for his blazer and has it running fine. He says its fast as hell.
RE: TWIN TURBO
well i was goin 2 go supercharger but just havent seen many good results from them. and then i heard about the twin turbo kit that mounts up with my 02 blazer and now i cant find it.
RE: TWIN TURBO
ive also not seen a TT kit for your truck...
RE: TWIN TURBO
well it looks like i will have 2 just design one myself then, but i have seen them tho
RE: TWIN TURBO
Go with the Gale Banks twin turbo kit for the small block Chevys. It is a good kit that will work for you too.
RE: TWIN TURBO
sure? exhaust manifolds, brakets etc would be dif wouldnt they?
RE: TWIN TURBO
you could try the manifolds off a typhoon
RE: TWIN TURBO
the typhoon would work to, I keep forgetting about those pimpy trucks. and the banks twin turbo should bolt right on because a 4.3 is the same thing as a 350 minus 2 cylinders.
RE: TWIN TURBO
but there may be clearance issues with the typhoon parts??
| All times are GMT -5. The time now is 07:58 PM. |
