wanna be faster than a 00 sierra
i just recently purchased a 99 blazer ls 4wd. there is a guy who used to be a friend of mine who just bought a 2000 or so sierra reg. cab, i dont think its a 4x4 it doesnt say it is. anyway, it probably has the 5.3, which i know from my suburban is very nice engine, is there anyway that if we lined up (at the track) that i could take him. i have magnaflow catback, jet performance module, k&n fipk, and shift kit. i dont have a g tech or anything to yell me my power or 0-60's but i've looked up the specs on the sierra and they are around 16 sec quarters. what else can i do to get better than that
RE: wanna be faster than a 00 sierra
a 100 shot should get you what you want
i hadnt even considered that, a 100 shot would put me well over 300hp. and i have never dealt with nitrous before.
Nitrousis only a short term solution. It gives you that extra boost when you press the button and then you go back to the same specs. Try some actualpower upgrades, like porting and polishing the heads, bore it out a little bit, get a shift kit, a supercharger or a turbo, get a tuned filter box and a high flow filter, do something that gives you the power your looking for all the time not at short intervals.
rabbit have you actually ever used spray? i have and its fine..... cost effective.... the 4.3L needs to be boosted..... thats why all the fast ones are turbo..... no s/c's, no all motor. there are some quick spray'd ones. Sebast on s10forum is running mid 11's with biult motor and spray. JDB is running 12.2 with a procharger @ 17psi on stock motor.
what you sited as a weakness is its exact strength.... you can turn it off. MPG stays the same driveability stays the same not many other required mods except a coil, plugs, wires, and a cut-out. put you in the low 14's easy on a 100shot. its alot cheaper then a s/c or turbo..... i built my turbo set-up and yes its ALOT faster but i cant turn it off and i am always laying into the throttle for fun.... fun = bad mpg. if you think a shift kit is gonna make you go faster........its not. a torque converter will but only really reason to put a shift kit into your tranny is to make sure the transmission doesnt blow up when the extra torque is added to the drivetrain. i have a shift kit and servos.... and yeah it lights 2 second gear up when it shift into it but its only for the added strength.... it can get very annoying as daily driving because of the "clunk" into second @ low rpm. i say go with a 100shot, cut-out, TR6 plugs, and msd plug wires.... thats all you should need. it will be fun then. also i wouldnt waste my money on a s/c for the 4.3L's ever UNLESS ITS A PROCHARGER. when you only make 225whp @ 9psi you suck @ life (powerdyne). for some reason s/c's dont react well @ all with this motor. i made 25more whp & 80more ft.lbs @ 1 less psi on my turbo set-up AND IT WAS RUNNING SO RICH THE DYNO COULDNT EVEN REGISTER IT. so i could probably hit 270whp on that dyno with some tuning. the procharger is nice but to bad the kit is $6,000 for our trucks. there is a guy on s10forum who is an S10- he has an RCSB S10- w/- Powerdyne @ 9psi + a 75shot + gears + locker + slicks and he was a tenth slower then me when i was only @ 8psi turbo on street tires and open diffrential. a fully built 4.3L which takes prolly 4K to build will only make 300 FLYWHEEL HP (10:1 CR, cam + heads + valvetrain+ cusomt MPFI) i have had both turbo and nitrous and i would take turbo over nitrous anyday of hte week. but nitrous is much mroe cost effective and can be turned off. also its not gonna screw your motor up unless your a dumbass. |
Hey killer..calm down. I was just lending MY OPINION. In my opinion NOTHING beats building your own engine from the ground up. I don't believe in spray and I have NEVER had to use it. ANY engine I have ever built be it a 4 cylinder or a V8 have all been able to take a car/truck on spray with an engine of its own size and a little bigger without using spray, just off sheer power. In my opinion he needs to build his engine up with a few g's worth of parts before he decides whether or not to use it, but IN MY OPINION he doesn't need it, it's a crutch. By the way I never ever said anything about a shift kit making you go faster, it's simply to help your tranny manage all the power you are going to force through it. Also, I dont remember him being concerned with mpg's or spending a little money to punk out his friend.
lol
Spray is for wussies...
[align=left] [/align] |
ORIGINAL: DankBlazer Spray is for wussies... [align=left] [/align] When used correctly, there is nothing wrong with nitrous oxide and it is a very good performance boost. Would I use it, not at this time, but then again, my Bravada does what is required of it just fine and my other DD has a blower. If I were to do anything with my Bravada, it would be simply for something to do. |
nitrous or turbo he doesnt need a rebuild to go fast.......
everyone on s10forum tells me im gonna blow up and the motor is gonna blow.... i have yet to, and it sees the track 3 times a month, and lots of street races. the BS 4.3L motor is alot stronger then most people give it credit for... JDB running 17psi on stock bottom end proves that. i sprayed the 100shot ALOT- @ one point 2+ bottles a week. just becuase of the rush it gave me..... he will be fine with a 75shot or 100shot....... anymore then your asking for trouble....... but in reality all he should need is E-fans, pullies, edelbrock TES, intake, cut-out tune and stall.... woud put him in the low 15's to high 14's depending on traction. buts cheaper to just put some spray and a cut-out on it. and easier...... nitrous is actually becoming the safest power adder..... with all of hte new safety percuations and parts comming out for it (a/f ratio shut off switch, FPSS, automatic bottle heaters, blow down tubes, etc...) but the main defences against engine damage is the driver/user...... fact of the matter is.... an N/A motor of the same size as a Turbo/supercharger/nitrous motor will never make more power then the forced induction motors.... .also the forced inductions engines will be more driveable and get better gasmileage and have the option of running 300whp instead of 700whp all the time. with just a tune, and traction im confident i can put my truck in 12's WITHOUT EVER REMOVING THE VALVE COVERS...... cant do that n/a. if you ever own a boosted vehicle you will know........... |
It's like having a conversation with a wall. :eek:I have given my opinion, so feel free to flip the rant switch again. [sm=rant.gif] Sorry, I didn't know that you knew it all.
You could argue this point all day long guys, the fact is that either method will yield the result he is after. I built an engine,trans and diff.for mine (my car that is...IMO blazers are not race cars...lol)others use nitrous, super chargers, turbo chargers...etc and some leave it stock and claim they have done this and done that....lol Bottom line...just get some EDUCATED opinions and decide which route is best for your budget, skill level, vehicle...etc...
ORIGINAL: lastcoupe You could argue this point all day long guys, the fact is that either method will yield the result he is after. I built an engine,trans and diff.for mine (my car that is...IMO blazers are not race cars...lol)others use nitrous, super chargers, turbo chargers...etc and some leave it stock and claim they have done this and done that....lol Bottom line...just get some EDUCATED opinions and decide which route is best for your budget, skill level, vehicle...etc... |
i would like to say that im educated on this subject having had 2 different power adders on my truck and building both set-ups myself and making them work..
WOW, people these days get offended WAY too easy, CALM DOWN SHOOTER, jesus
( In response to swart and 02vortec ) [align=left] [/align] |
ORIGINAL: DankBlazer WOW, people these days get offended WAY too easy, CALM DOWN SHOOTER, jesus Well, maybe next time youshould lend some knowledge or experience to the debate, rather than makingobtuse comments. |
are you kidding me read the post #10...... i wrote a friggen ESSAY of info... i can go deeper into the details if you like.....
ORIGINAL: 02 Vortech i would like to say that im educated on this subject having had 2 different power adders on my truck and building both set-ups myself and making them work.. |
ORIGINAL: DankBlazer WOW, people these days get offended WAY too easy, CALM DOWN SHOOTER, jesus ( In response to swart and 02vortec ) [align=left] [/align] But really, there is no need to get all worked up over this stuff. Any further bickering in this thread will be deleted. |
Just to clear things up, my comment in post #16 was not aimed at you 02vortech. Let's just agree that there are many different ways he can go about building a setup on his engine. Your opinion is the way of spray, mine is a engine build-up with a turbo or s/c to finish it. Fair enough? No need to "bicker" as Kyle stated.
what is a TES exactly?
*combining consecutive posts* i have no problem going nitrous, and probably will, but if i do i definitly want all the safety features you were talking about. *EDIT: swartlkk* - Combined consecutive posts. Please use the edit function to add additional information to your post if another member has not yet replied. |
Edelbrock TES = Edelbrock Tubular Exhaust System
Its what Edelbrock calls their headers. |
well i just found out he has the 4.8, so maybe i have a chance. especially with a nitrous system. would a fogger be okay, i know someone with one for sale
Gonna go heads up? aah yes, nitrous, love it or loathe it. Careful you my ruin your motor.
from a little bit of exp. your truck, the way it sits now will lose to his sierra, but if you do any of those mods (blower, turbo, nitrous oxide, and possibly builing up the motor depending on what you actually do) you will beat him. The 4.8 shines in the high reving department. of truck engines and in my opinion the 4.3 which is based off of the 350 is a torquey motor (just my opinion atleast thats what GM's goal was when they built the 5.3L and 4.8Lto replace the 5.7L and 5.0L) anyways if you can use the weight advantage you may have, and turn the 4.3L into a fast reving motor you will win hands down. On the other hand he has 2wd and its a regular cab so he is really light, and has alot less power loss by having 2wd, when you order a 2wd truck they typically come with 3.23s, 3.08s and sometimes 3.42s. rarely in a half ton do you actually see them with 3.73s like my truckor 4.10s(my truck is a 4x4 z-71). This is to your advantage since he has no 5.3L for the gained torque and he now has crappy gears to get him off the line.anyways thats just my opinion for whatever its worth hopefully you all agree and i brought up some valid points.[sm=icon_cheers.gif]
i have a 94 s10 blazer with intake headers and full exhaust no cat and 186k on it and i can beat stock 1500s all day along with f150s
Holy old thread... Thanks for your contribution.
wow old thread.... sounds interesting to me that you can beat 1500s stock are you talking about 4.8, 5.3, and 6.0s also not just v6 work trucks? because that vortecmax would walk away from your truck if all you have is headers its actually an ss with a normal body in a half ton truck very quick!
I cant hold a candle to our 2003 silverado 5300...lol
I agree with 2001blazer you going to need to pack in a sh*t load of parts including a blower or turbo to even put a dent in traking a fullsize truck. Only if its a V6 work truck would somewhat be even. Remember these engine are based off of a 350 with 2 less cylinders and are very torquey and for the most part are low rpm engines. Mine lives in the 1,200 to 2,000 rpm just driving. When I am taking off or when I need just a little more 2,200 rpm to 3,000 rpm. 3,000 rpm is nothing compared to where most vehicle live rpm wise. Remember we may not have the biggest engines, the lightest trucks but from what I can tell we have just as much if not more fun than Jeeps. My dad has a Jeep and hes kind ofa diehard with jeeps, but he admitts that I can hold my own on a trail and believe not a couple time I have got through shi't that he spun and got hung up in.
everyone has made many great points in this whole thread i read all of them and i had to add my experience in the whole fullsize versus s-series mine is a classic one my best friend has a 98 1500 with the 5.0 in it with a throttle body spacer c.a.i. and a flowmaster exhaust so of course he said that his was alot faster well all i have is the poor mans c.a.i. which all i did was take out the factory air box and threw on a cone filter and then did a tune up the same time he did his well we went out to the track just to be fare we lined up and i took him by a respectable gap well i beat him by a length and a half and we both have automatics. it surprised me when it happened then we did it again same result. you just have to quick on the throttle but if your buddy has a 5.7 then yea you will need some extra power. take the advice given previous to you.
Im happy beating the crap out of those h3's and colorado's. PFFT 5 cylinder saab motor.
Torque makes the world go 'round.
Personally, I'd much rather have the 5.3 in my Blazer... A turbo might be nice, but most don't spool effectively until at least 1500 - 2000 RPM, usually more, which isn't much good when crawling up a hill, lol. Odd that the Colorado/Canyon would be slower than a Blazer (assuming the Canyon/Colorado is 3.5 or 3.7 equipped) since it makes more HP, almost as much torque, has a much flatter torque curve, and weighs less... |
I guess im just really cool?
Well, there's that, but I've done it too... Heck, my old Z34 could do it...
I think there's something in those things that's messing up... (Could be the engine, lol) |
