1 bolt stands in my way
so im putting lift shackles on my blazer. well, trying to. 1 bolt is stoping me from doing this. the bottom bolt on the drivers side that connects the leaf to the shackle refuses to come out. ive drenched it in PB blaster, hammered the crap out of it, even took an air gun to it. still wont come out. Ive gotten the nut off the bolt, but thats it. any suggestions on how to get this thing out? My friends neighbor said he could use his ball joint splitter to press it out but do you got any other ideas?
RE: 1 bolt stands in my way
Hmm, thats kinda odd. For mine it stuck a little so i just used a random bolt i had laying around and a big sledge hammer and it just popped out. What seems to be stopping it, can you tell?
Can you turn it in the bushing? If not, you need to get a breaker bar and push and pull on it as many times as it takes for it to start moving freely...
Im pretty sure its stuck in the bushing. It takes some muscle but but when it turns, the bushing actually turns with it from what it looks like. I tried beating it with a hammer today, ended up smashing my thumb.
Help...I'm having the same problem! Both of the front bolts on my 95 s10 leaf springs are stuck. I used a 18# sledge hammer with no luck. How did you finally get yours out?
I didnt Ive put that project off for now, need to put my money towards college and stuff.
Are the bolts able to turn? Get them free first, ratchet them cw and ccw for a bit. Then what I did was used a punch and a bfh and hit the bolt. Hit it a little out, then back in, out, repeat. Use lots of pentrating fluid and you will get it.
Get you a big ratchet and a four foot long metal pipe. that should break it loose... or break it...LOL
had the same problem on the lower bolts so im just went and got new bushing today and bolts and im cuttin those damn things out. but the top ones broke loose easy.
and if all else fails....Bolt cutters.
