2005 blazer lift kits??
I have a 2005 blazer base model, 4wd, 2 door. I am looking for a 4-6 inch suspension lift online. just wondering if anyone knows where I can find one? I could only find a 2.5 inch on rough country.
4/6 inch lift will surely screw your front end geometry.
Originally Posted by LeWhite
(Post 645520)
the 2dr will likely cause drive shaft angle problems
2.5 suspension + 2 body ??? |
I would say go with the 2.5 suspension and a 2 body. That's generally the common setup and will get you in the 31" tire range.
search for a 2004, you might have better luck. a lot of websites only list up to 2004 for Blazers.
You can clear 32x11.50 with some tbar crank will rub at full lock on stock rims
| All times are GMT -5. The time now is 05:23 PM. |
