Suspension Tech Have a question about modifying your suspension? Ask it here.
Wheel spacers
Old 02-28-2019, 07:49 PM
iceblue068's Avatar
iceblue068 is on a distinguished road
Default Wheel spacers
How much wheel spacing should I probably need in the front of my 98 blazer in order to keep from scrubbing the sway bar when I turn?
Old 02-28-2019, 07:56 PM
cleburne red's Avatar
How wide of a tire, and what size rims are you running?
Stock sizes shouldn't rub. If they are, you either have something bent, or need an alignment
Old 03-01-2019, 04:55 AM
iceblue068's Avatar
Old 03-01-2019, 05:18 AM
What is the backspacing on your rims? That works out to just under 10.50". I'm running 10.50s on my truck, with a 4.5" backspacing, and I have no rub on the frame or sway bar at all. Stock 4wd rims have 6" BS, so it seems like moving the tire out 1.5" does the trick
Old 03-01-2019, 08:16 AM
iceblue068's Avatar
Thanks
98jimmyengine
Suspension Tech
10-07-2018 10:35 AM
2000BlackBeauty
Tires and Wheels
10-10-2013 09:40 AM
arroyo-blazed98
Tires and Wheels
03-10-2013 02:28 PM
-Z-
Lifting Tech
12-09-2010 07:45 PM
casper975
Tires and Wheels
12-06-2010 02:19 PM
Quick Reply: Wheel spacers
