Hey guys quick ques..
diff springs? meaning rear end leaf springs?
i thought about removing the over load spring. ont the leaf springs to make softer. but in front i have tor bars dunno if i lower it a bit will it make it softer?
when you lower the front your compressing the suspension if you lift it your taking stress off with the shocks in the rear it shouldn't be bouncy plus you have the other leafs in there its not like your mono leafing it (which is only leaving one leaf in when lowering it )
i dont think adjusting the tbars would really help. it will also put more stress on other front suspension components. you might think about checking all of the bushings and joints. make sure they are all in working order and grease whichever ones you can.... shocks will also help. they made a big difference forme, however i wanted mine stiffer and less bouncy.
