I've decided on a 5" lift but...
I dont know which one I want to get....
I've been reading around here a lot and feel the best choice for me would be a 5" lift for my 97 blazer. I plan to do all the work myself to keep costs down although it will be my first truck lift...i have plenty experience in tuning cars/turbos/engines but when it comes to suspension...it will be somewhat of a first.. From what I gather on here, the BDS OR SUPERLIFT would be the best 5" lift to get..my question is: is there other/better 5" lifts out there and what major problems would I run into in the installation... I'm not looking to spend too much of an arm and a leg...maybe $2,000-$2,500...gunna try to keep it under $3,000 in total mods...the blazer has 215,000miles on it and I just got BFG Mud Terrain KM2 tires.. I had the mud terrain KMs on my zr2 in HS and loved them so I bought some for the blazer. Any suggestions or input welcome Here is my blazer http://i665.photobucket.com/albums/v...-27-26_312.jpg http://i665.photobucket.com/albums/v...-44-22_962.jpg |
Your options are limited. Trailmaster is the only other company that you didn't list. Those 3 are it for keeping the ifs and lifting.
Originally Posted by neo71665
(Post 493777)
Are those three kits all around $2,000? |
I went with a 5 inch bds lift.
You will get a better price if you go to a local place and order it thru them. That saved me couple hundred right there. It took me roughly 24 hours of labor to do the job. If you take your time and atudy the manual it can be done. I recommend a torch if you have access to one..also keep in mind that the normal 3 ton jacks will only help you thru part of the lift...halfway thru you will need taller stands like the 6tons stands. Also the rear stabilizers dont come with the bds kit...you can either leave them off..body roll will be felt..order the kit or extend the stock ones with a weld job and some steel pipe. Having a helper will make a huge diff when pulling out the front and rear axles. Should also do tie rods and ball joints and lower control arm bushings. As well as the bushings for the torsion bar cross member. I did some things after the lift for budget reasons. I could add more...feel free to ask away. |
Originally Posted by warthogdriver
(Post 493787)
You will get a better price if you go to a local place and order it thru them. That saved me couple hundred right there. It took me roughly 24 hours of labor to do the job. If you take your time and atudy the manual it can be done. I recommend a torch if you have access to one..also keep in mind that the normal 3 ton jacks will only help you thru part of the lift...halfway thru you will need taller stands like the 6tons stands. Also the rear stabilizers dont come with the bds kit...you can either leave them off..body roll will be felt..order the kit or extend the stock ones with a weld job and some steel pipe. Having a helper will make a huge diff when pulling out the front and rear axles. Should also do tie rods and ball joints and lower control arm bushings. As well as the bushings for the torsion bar cross member. I did some things after the lift for budget reasons. I could add more...feel free to ask away. Anything is helpful..... Do u have a thread of your build? I've looked up and down the suspension lift board and am just now getting to posting... How's the steering linkage maintained after the lift and can you do a body lift on top of these lifts? |
Under my sig is a build link...also link to photobucket lots of pics in there.
it was my first lift...i took my time. I guess a pro would be 10-12 thats the est i got from shop i bouht kit from...they told me 60 an hour for labor of 600..sounds right. I am not a trained mech but i am good with tools. Most intimdating part is starting to cut the upper arm supports at frame..point of no return. Look at the manual on the bds site..its a good pdf..lots of pics. Study it and see what you think. It is involved but straight forward. Yes i have a 2in body lift to...the steering also can have a stabilizer mounted up to help. The steering is not affected ..the steering stays put on the frame. |
u can sas it for the same price if not cheaper. the axles will be the most expensive part. if u go with a dana30 for the front and a dana35 for the rear out of a jeep wrangler ul have gears and the 5" lift u want. then ur platform is there for when u wanna make it ur winter beater. u could use the springs from a wrangler too, plus the pumpkin will be on the side u need too. i sas mine with dana44s.....with the axles, springs, spring hanger for the front and misc b.s like brakelines and u bolts and such i was into it around $2200. so heres another option..... :)
Originally Posted by duxtoyz
(Post 493819)
As far as install times and complexity how do they differ? And Warthog.... I noticed that right after I posted |
This is a tad off-topic, but figure I'd ask. If you order the kit soon and put it on, are you selling your new mud-terrains for bigger tires?
Originally Posted by tibby
(Post 493977)
