Suspension Tech Have a question about modifying your suspension? Ask it here.
Link type Torsion bar mount help 2000 jimmy
Old 09-16-2013, 02:33 PM
95blazerlt's Avatar
95blazerlt is on a distinguished road
Default Link type Torsion bar mount help 2000 jimmy
So i got this annoying pop when leaving a stop sign, or when i am stopping. it also makes a poping noise when going over bumps. I stuck a pry bar beside the frame and torsion bar crossmember and i can move it side to side enough for it to hit the frame. i think this is were the popping noise is coming from. I searched on here and found that if i had the regular mounts i do not have to unload the torsion bars to change them, just use a floor jack under the crossmember. But havent found any info on replaceing the link style . basically i am wondering if its possible to change them without having to unload the bars..
Old 01-28-2018, 07:14 AM
randal4×4's Avatar
randal4×4 is on a distinguished road
Did u ever figure this out I'm in t he same boat right now
Old 03-01-2019, 04:35 PM
Night_Wolf's Avatar
Night_Wolf is on a distinguished road
I just did these back in December, I jacked the front end of the truck and set it on jack stands so both wheels were off the ground and removed and replaced the links one side at a time without any problems. There’s a nut on the bottom under the crossmember and then there’s a bolt and nut for the top one. You’ll need to put a socket in a hole in the frame to hold the bolt still while you unscrew the nut.
Brandon Koharchik
01-20-2018 06:38 AM
chris015
04-24-2011 06:52 PM
musclecar70sfan
07-05-2010 10:02 PM
S10Blazer
12-23-2007 10:47 AM
Mbastet99
11-07-2006 07:52 PM
Quick Reply: Link type Torsion bar mount help 2000 jimmy
