-   Suspension Tech (https://blazerforum.com/forum/suspension-tech-12/)
-   -   Looking to clear 32x11.50 tires and aftermarket wheels (https://blazerforum.com/forum/suspension-tech-12/looking-clear-32x11-50-tires-aftermarket-wheels-9510/)
Arthur 03-22-2007 11:38 PM
Right now I have 31x10.50 BF Goodrich All-Terrains on the factory rims. The only suspension work I have done is an add-a-leaf and a torsion crank. This clears the tires really well, but I'm looking to go a little bigger. I plan on getting 32x11.50 tires; they are not only taller but wider. On top of that I plan on putting on RockCrawler wheels which will make the tires stick out a little further. I know that it would rub pretty bad on the set up I have for me right now. My question is would a 2" body lift allow the clearance for the new wheels and tires?
Blazin_Jason 03-23-2007 12:00 AM
RE: Looking to clear 32x11.50 tires and aftermarket wheels
What's the reason for wanting to get the 32's? The BL will help but I would think that if you don't have enough backspacing you will hit on the fenders.
Jigg 03-23-2007 11:30 AM
If you keep the stock rims, trim the fenders, add shackles, and crank your t-bars... you can run those tires.
Otherwise, you're going to rub.
Arthur 04-06-2007 12:51 AM
Ok change of plan... I am going to stick with the 31's for a while, but I still want the new wheels.
With new wheels the 31's will rub, but its going to be easier fitting them than fitting the 32s. I dont know too much about trimming fenders, but I do know that I dont want to do it myself. If I got a new torsion key and cranked up the t-bars the rest of the way do you think I could fit those wheels? If not how much do you think it would cost to pay an offroad shop to trim them for me?
drperry 04-06-2007 08:43 AM
Watch your ball joints and cv axles if you're going to do any off-roading with a maxed out t-bar crank... it increases the wear on those parts by a whole heck of a lot...
Arthur 04-07-2007 03:13 PM
I know about wearing out the parts... I'm just wondering about clearance right now and fender trimming prices right now
zero psi 04-08-2007 12:48 AM
I plan on clearing 32's with a 2 inch body lift and some fender trimming. But i'm going to wait until i can find a used set for a good price.
http://img.photobucket.com/albums/v8...iend_96dpi.jpg
mscott03 04-18-2007 09:53 AM
Im running on 32's. 2" Body Lift, torsion bar crank about 2", and fenders needed to be cut.
