-   Suspension Tech (https://blazerforum.com/forum/suspension-tech-12/)
-   -   lowering help (https://blazerforum.com/forum/suspension-tech-12/lowering-help-4061/)
joeyg Jun 22, 2006 05:32 PM
lowering help
anyone kno where i can get a lowering kit?
LORCLAS Jun 22, 2006 05:51 PM
RE: lowering help
Nobody makes a kit for Blazers that I could find. What year do you have? How low do you want?
My first drop was a static drop on my 2004 Blazer Xtreme. Used 2-inch drop spindles, 3-inch shorter coil springs and 3-inch lowering blocks in back. All from Belltech. Also ran Belltech Nitro-Active monotube drop shocks on all four corners. Also recommend a C-notch.
joeyg Jun 22, 2006 08:22 PM
RE: lowering help
i got a 95 im lookin to possibly go 3 in the front 4 in the back
blazin97 Jun 25, 2006 02:33 PM
RE: lowering help
Belltech and DJM make drop kits for the blazers. Thats if you are looking for a satic drop.
LORCLAS they do make kits for the blazers. Both static and air ride.
LORCLAS Jun 25, 2006 08:44 PM
RE: lowering help
Sorry. Posted response wrong. I could not find places that sold a specific "kit" for Blazers. Found plenty of places that sold individual components to make up the kit, but not a "kit" in the specific term. :D
Example No kit for Blazers
http://www.stylinconcepts.com/parts....rtfamilyid/825
Go to www.stylinconcepts.com and make a Blazer your vehicle and do a search for a lowering kit and it will say that there is not one available. But change it to an S-10 pick-up and there are plenty of kits offered.:D
blazerboi5 Jun 26, 2006 01:11 PM
RE: lowering help
you can get just about anything you want for lowering from www.stylinconcepts.com
djbass_mekanik Aug 27, 2006 04:47 AM
RE: lowering help
im thinking of lowering my truck... 3/3 drop.. what would you reccomend?? 2" spindle/1" spring and block... or 3" control arm and block... if u kan, wat are pros and cons.. and price diff.. thanks../
Tsa_Performance Aug 27, 2006 03:01 PM
RE: lowering help
id go beltech. ive read alot of good stuff about their stuff...
blazin97 Aug 30, 2006 04:27 PM
RE: lowering help
ORIGINAL: djbass_mekanik
Depends what you wanna spend. control arms are $250 or so, 2" spindles are $150 or so, springs are $100 or so and blocks are $30 or so. If you want good stuff I'd go with spindles and springs up front and leafs in the back $200 or so. Any time you use drop springs you need to get your alighnment fixed.
