Rancho 9000XL SHOCKS
Any one use these i was planning on getting them for the rear for now but do they ajust the heght or only ride quailty ?thanks>
http://www.my4by.com/rancho-rs9000xl...nt-p-2640.html |
they just adjust the ride quality. i have them on the front of mine and they're allright. there is a plastic knob that allows you to adjust the dampness (how quickly the truck returns to full ride height after compression of the shock)
if you want some lift in the rear. i would go with air shocks. i have monroe air shocks that i got at advance auto for $70 (a pair, and all the stuff to put it togther, air tubing, fill valve, etc.) or a shackle lift |
As said, they only help ride quality. Shocks do not add lift unless specifically designed to do so (air shocks or coil overs).
I went with the Monroe Sensatrak w/ load assist coil over shocks in the back of my Bravada. I have had a few air shocks blow quickly in the past. |
thanks for the tips so those Monroe Sensatrak w/ load assist coil over will lift it abit ?
