rear leafs
does anyone know what the measurement is from the center of the back tire to the bottom of the rear wheel well bc im trying to figure out if my rear leafs are sagging or not and to me it seems that they seems to be s bending on me so ill proly be changing them anyway
You can get new ones from the dealer for $85 and it comes with bushings. I got slightly used ones and I am putting energy bushings in them.
Originally Posted by musclemasterflex
(Post 466056)
$85? where are you finding yours? I looked it was $300 per side... got a set of junks for $100 and made my own add a leaf for the price of a couple sawsall blades and drill bits (also new bushings)
rear leaf spring installation
I have a 99 4wd Blazer. I am putting new rear leaf springs and shocks on. I got the old ones out but I am having a problem putting the new ones on. I put the front bolt on then put the rear end of the spring to the shackle. That is looking fine. My problem is that the small nipple does not line up with the hole. So when I go to put the new u bolts on they are bent. It seems like the spring needs to be pushed in towards the center of the Blazer. Any hepl or pictures would be great. Thanks Bernie11
