Suspension Tech Have a question about modifying your suspension? Ask it here.
Suspension lift question
Old Mar 2, 2016 | 05:10 PM
kwdport's Avatar
kwdport is on a distinguished road
Default Suspension lift question
I have a stock 2000 LS4x4 wanting to add a suspension lift. Does anyone know if this will give me 1-3 in in the rear or the front. Without anything else. And if I do need something else what is it?
Old Mar 2, 2016 | 06:05 PM
TMM217's Avatar
TMM217 is on a distinguished road
The leaf shackles will give you 2" in the rear. The torsion keys lift the front without bottoming out the adjuster bolt. Front will be adjustable but 2" is the most you should go. Rough Country has a kit that comes with new upper controls arms to help with alignment and ball joint wear and a differential drop bracket to reduce angles on the cv shafts.
Old Mar 3, 2016 | 10:23 AM
97blazerking's Avatar
97blazerking is on a distinguished road
look for the package deal there cheaper then buying them seperate
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
