Tech: Lube up leaf springs
http://img.photobucket.com/albums/v4...h_P3070010.jpg
I jacked the truck up and sprayed lithium grease between the leaf springs. I did a rear brake job and took it out for a ride. I noticed a sqeek it had is now gone. I would recommend any do this if a noise is suspected in the rear. P.S. Don't mess w/ the parking brake shoe. I tapped it to get some dust off and it dragged on rotor when I drove. P I the A to get it centered. A good hammer will suffice. |
RE: Tech: Lube up leaf springs
Excellant post. I saw a similar one on another forum and I plan on doing it this weekend.
The lithium grease may not last all that long. For longer protection, you could try to put on a standard grease between the springs.
I know on several other trucks that I have worked on, there were rubber isolators between the ends of the springs. Kind of sucks that we don't have that option on ours. Makes for a nice quiet ride. |
Excellant post. I saw a similar one on another forum and I plan on doing it this weekend. (in reply to 4lowlife) The lithium grease may not last all that long. For longer protection, you could try to put on a standard grease between the springs. I know on several other trucks that I have worked on, there were rubber isolators between the ends of the springs. Kind of sucks that we don't have that option on ours. Makes for a nice quiet ride. *sigh, the good 'ol days. |
I don't think that antiseize would work well at all. It is meant to be squeazed into tight areas. It will dry out over time just like lithium grease and will make a mess besides. The best thing to do would probably to put in a thin peice of rubber to isolate the springs, but I'd have to take a closer look to see how to retain the rubber.
| All times are GMT -5. The time now is 09:02 AM. |
