Tire interference
I just bought a 95 S10 Blazer 4x4 4 door. I have some 31 x 10.5/15 BFG A/T's that I want to put on it. It looks like the front tires will rub the back of the fender in the turns just a bit (a bit too much). What's the easiest/cheapest way to eliminate this contact? Lift the front a bit? If so, what's the easiest way to accomplish that?
Thanks for your help, Ed |
RE: Tire interference
you can probably tighten on your torsion bars a little to raise your front end. It can bring it up about 1 1/2 inches, but it will change your ride to make it a lot stiffer. You would also want to bring up your rear end as well and there are a few options with that. . . you can guy shackles to offset the springs or blocks. . . blocks are the better way to go i think.
| All times are GMT -5. The time now is 06:44 PM. |
