-   Suspension Tech (https://blazerforum.com/forum/suspension-tech-12/)
-   -   Torsion Bar Crank vs. Torsion Bar Key Lift (https://blazerforum.com/forum/suspension-tech-12/torsion-bar-crank-vs-torsion-bar-key-lift-16856/)
tt0876 02-01-2008 08:12 AM
I need to get the front end of my 02 ZR2 Blazer raised up. I know I either need to go in and crank my torsion bars or that I need to install new torsion bar keys to get the needed lift. Is one of those options better then the other or will the have the same effect on my ZR2? What kind of negative impact could doing those things have on my ZR2?
95_4door 02-01-2008 09:29 AM
RE: Torsion Bar Crank vs. Torsion Bar Key Lift
Click here. It will help you out tremendously. Use it often, most ofyour questions have already been asked, and answered.
YepIOwnA97Blazer 02-01-2008 02:11 PM
i think it would be good to answer them in one thread a lot of questions are answered halfway thru general lifting threads, the title of this one should help out a lot of people.
Arthur 02-07-2008 01:04 PM
torsion keys will allow you more room to crank your bars up... Thats what i have done on mine... the negative effects is a stiffer ride and it puts more stress on the cvs... here is a picture of mine with torsion crank, add-a-leaf, and 31's...http://memimage.cardomain.net/member...59_31_full.jpg
navyblue_sk8er 02-07-2008 06:04 PM
True the main difference is new torsion keys is going to make the front end stiffer. Add a leaf is going to make your rear stiffer. So I think it all depends on what your doing. If you are going to do a shackle lift in the rear then I would keep your stock keys. But if you are doing a add a leaf to the rear then I would get new torsion keys. That way your suspension is nicely evened out.
Stock torsion keys + Shackles = Stock suspension ride
New Torsion Keys + Add a leaf = Stiffer suspension ride
But I'm no rocket scientist
drperry 02-07-2008 07:15 PM
All torsion keys do is let you crank the t-bars PAST the stock maximum...
You're gonna be replacing balljoints, CV axles and stuff more often...
a_tack 02-07-2008 10:08 PM
if you are dead set on cranking and want to buy torsion keys, you should consider a rough country 2" suspension lift.... It has new torsion keys with it, however, it comes with new upper control arms. The new upper control arms hold your upper ball joints at a different angle to greatly reduce wear on them... They will still wear out, just not nearly as quick as they will with your stock upper control arms and a torsion bar crank.
fst450 03-26-2008 04:42 PM
does anyone no of any othercompanys like rough country that has the2 inchlift with upper balljoints and control arms reason being i live in canada and they dont ship here? thanks
drperry 03-26-2008 05:04 PM
Go to a local truck shop, and they should be able to set you up...
LTblazer21 05-05-2008 11:32 AM
I'd like to know if the stock torsion keys from a ZR2 are the same as the ones from an LT blazer...Would I benefit at all from using the ZR2 keys on my LT?
