Trying to lift my 2000 zr2 blazer
How can I lift my blazer? My leaf springs are on the bottom of the axle is there anyway I can put them on the top so I can easily install lift blocks to my rear end. If not what do I have to do for my rear? My front end sits higher, I want the back even with it. Thank you!https://blazerforum.com/forum/webkit...8768/imagejpeg
Body lift would be easiest and cheapest. It wont make the truck level but it will give lift. And to lift the rear you would just need longer shackles. Swapping your axle over will give you way too much lift unless you back side is a good 5" lower right now.
Edit: Also your picture doesn't work |
