Suspension Tech Have a question about modifying your suspension? Ask it here.
Vehical Sway??
Old Dec 8, 2005 | 09:21 PM
89Blazze's Avatar
89Blazze is an unknown quantity at this point
Default Vehical Sway??
1989 s-10 4x4....4.3L...My question is...My vehical seems to have sway from side to side and a knock coming from the rear of the vehical when i make a left hand turn.....as far as the suspension is concerned i have only installed sensa-trac schocks....Has anyone ever experienced such problems if so ur input will be greatly appreciated...thanks in Advance
Old Dec 8, 2005 | 10:58 PM
Default RE: Vehical Sway??
I don't know if your truck includes a rear anti-roll bar, but if it does, check your links on the rear roll bar. Even if it doesn't, check over the suspension on all 4 corners. Look for anything out of place and compare side to side. Even if you don't know what you are looking for/at, you'll be able to tell if there is something awry.
Old Dec 16, 2005 | 06:33 PM
Hanr3's Avatar
I would agree, it sounds like one of your anti-sway bar bolts has broken off. That or a shock mount has busted free, but that is usually on struts, not shocks.
Old Dec 20, 2005 | 11:25 PM
20Blazer00's Avatar
You might also check the panhard bar that locates the rearend from side to side. Bushings maybe worn or maybe also be a broken mount location or bolt.
pj5454302
Lifting Tech
Jan 21, 2010 08:19 AM
jaybird33081
Jan 4, 2010 03:12 AM
powwowblazer
Suspension Tech
Jun 26, 2006 05:22 PM
cherryred4x4
Suspension Tech
Apr 4, 2006 08:05 PM
timetoblaze
Suspension Tech
Oct 30, 2005 12:17 PM
