Vehical Sway??
1989 s-10 4x4....4.3L...My question is...My vehical seems to have sway from side to side and a knock coming from the rear of the vehical when i make a left hand turn.....as far as the suspension is concerned i have only installed sensa-trac schocks....Has anyone ever experienced such problems if so ur input will be greatly appreciated...thanks in Advance
RE: Vehical Sway??
I don't know if your truck includes a rear anti-roll bar, but if it does, check your links on the rear roll bar. Even if it doesn't, check over the suspension on all 4 corners. Look for anything out of place and compare side to side. Even if you don't know what you are looking for/at, you'll be able to tell if there is something awry.
RE: Vehical Sway??
I would agree, it sounds like one of your anti-sway bar bolts has broken off. That or a shock mount has busted free, but that is usually on struts, not shocks.
RE: Vehical Sway??
You might also check the panhard bar that locates the rearend from side to side. Bushings maybe worn or maybe also be a broken mount location or bolt.
| All times are GMT -5. The time now is 11:23 PM. |
