-   Suspension Tech (https://blazerforum.com/forum/suspension-tech-12/)
-   -   What the highest lift before you have to start tweaking everything else? (https://blazerforum.com/forum/suspension-tech-12/what-highest-lift-before-you-have-start-tweaking-everything-else-6352/)
Jimmiero 11-01-2006 07:31 AM
Ive heard that if you go any higher than a 4" suspsion lift you have to tilt your drive shaft or something of that nature is this true? I already have a 3" body lift and wanted more. I also have a set of 2" lift blocks and add a leafs sitting in garage if i buy a 4" lift kit could i just add my 2" blocks onto the 4" ones to make it 6?
Cow Killer 11-06-2006 01:27 PM
RE: What the highest lift before you have to start tweaking everything else?
for fullsize gods, go to www.ck5.com they will help u with anything fullsize.
if i remeber right, 4 inch is max on stock parts. the slipyolk in the xfer case will come out if any bigger.also the stock axles almost at thrie max for tire size. 35's are about max for a dana 44/12 bolt setup unless u are only driving it on the street, or baby it off road.
cody32401 11-06-2006 05:08 PM
we did 10-12 inch whiplash lift on a dodge only thing we had to change was the front driveshaft had to get it custom built
(i wouldnt recommend this though)
to many shots a jager since then cant remember what all was changed out but it came with everything you needed
LunchBox 11-15-2006 05:15 PM
ORIGINAL: Jimmiero
Not if you value your life. Very bad, bad, icky things will happen. Seriously, never stack blocks...
