-   Suspension Tech (https://blazerforum.com/forum/suspension-tech-12/)
-   -   Wheel spacers (https://blazerforum.com/forum/suspension-tech-12/wheel-spacers-98980/)
iceblue068 Feb 28, 2019 07:49 PM
Wheel spacers
How much wheel spacing should I probably need in the front of my 98 blazer in order to keep from scrubbing the sway bar when I turn?
cleburne red Feb 28, 2019 07:56 PM
How wide of a tire, and what size rims are you running?
Stock sizes shouldn't rub. If they are, you either have something bent, or need an alignment
iceblue068 Mar 1, 2019 04:55 AM
265/35/22
cleburne red Mar 1, 2019 05:18 AM
What is the backspacing on your rims? That works out to just under 10.50". I'm running 10.50s on my truck, with a 4.5" backspacing, and I have no rub on the frame or sway bar at all. Stock 4wd rims have 6" BS, so it seems like moving the tire out 1.5" does the trick
iceblue068 Mar 1, 2019 08:16 AM
Thanks
