02 Blazer LS 2Dr 2 Wd w/31's?
Hey,
I have a '02 LS 2Dr 2Wd and wanted to put a 2 inch body lift with 31/10.5 on 15x7" rims. Will they clear without rubbing? Also, I can't find my factory tire specs for the life of me; what is my factory rim and tire sizes with backspacing. What sizes would you recommend instead (with backspacing)?Thanks |
RE: 02 Blazer LS 2Dr 2 Wd w/31's?
Sticky at the top of the section entitled Helpful Threads (What size tires fit the S10-Blazers) should answer both of those questions. If it doesn't answer all of your questions, please post up in this thread again and we will try to get them answered.
*EDIT* - sorry, provided the wrong link above. Changed it. |
I have a bl with 31s and I rub only at full crank on the frame.
| All times are GMT -5. The time now is 06:37 PM. |
