16inch camaro rims
hey would 16 inch camaro rims fit on my 92 blazer? i figured they would becuz theyre both chevys and people put camaro rims on them all the time, BUT doesnt 4wd require special rims for the front?? ...
RE: 16inch camaro rims
i have heard they'll fit, but you'd be better off measuring backspacing on them to be sure.
you better check the bolt pattern offset 5(lug)x 1something im not sure on the exact but a rim shop should have that stuff on hand but some rims are made for rear wheel, front wheel and all wheel but your staying away from oversized rims so you should be fine
I have a set of Firebird rims on my '87 S10-blazer. They have like 6" backspacing. The rims are 16x8". Our lug pattern is 5x4.75". Camaros, Firebirds, and a few others will fit. Like they said check the backspacing and make sure the bolt patern is 5x4.75".
| All times are GMT -5. The time now is 06:37 PM. |
