-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   2000 Chevy blazer zr2 4x4 2 Dr (https://blazerforum.com/forum/tires-wheels-13/2000-chevy-blazer-zr2-4x4-2-dr-107171/)
Injun0222 Mar 1, 2025 06:26 PM
Need help, I need to know what is the widest tire I can put on my stock 15" rims / does not have a lift
AJBert Mar 1, 2025 10:32 PM
No more than 4 inches wider than the rim itself if I recall correctly. That would be 275 mm or 10.5 inches in common sized tires. However, plan on some rubbing unless you lift your vehicle and/or doing some trimming. Some tire shops may install wider tires, but most won't.
daveca Apr 5, 2025 05:42 PM
wide tires slowly kill wheel bearings. Avoid it.
El_Beautor Apr 7, 2025 10:16 AM
What AJBert said.
FYI, if you can find them, you should be able to put 255/70/15 tires on factory rims with factory suspension and not rub. I had that size on my 96 Blazer for a few years. They look a lot beefier than the factory 235's, but still fit with the stock suspension and are around the same height as the factory 235/75/15 that my Blazer called for.
