2000 LS Blazer 4door tire size
hey, probably a lot of threads about this but... i picked up for free, some 265/75/15 all terrains. stock on my truck is 235/75/15. will these 265s fit without any rubbing whatsoever? thx in advance.
Jay |
The 265/75/15 is essentially the same size as a 31x10.5x15. You can search all over the forum for people's experience with tires this size. Short answer: Without lifting with either a body lift or suspension lift at least 2" you will likely rub the frame and the rear of the front fender, and possibly the sway bar.
ok thx, thought it looked a little tight on the front. thought i was dealing with 30 in tires which is the biggest i can go without a body lift?
I have a 2" lift and 265/75r15 and they still rub on the frame, granted I drive a 2WD so a 4x4 might have different experiences.
