2004 2 door 2wd tire size question
Yes, I searched... and I'm overly tired of searching for 2wd tire size questions because EVERYTHING is about 4x4 blazers.
I just bought a 2004 2 door 2wd blazer ls and I would like to get larger tires/wheels. 1) What's the largest and widest size without lifting (not an option, wife has to be comfortable getting in/out) 2) What do you do about discrepancy in speed/mileage? 3) It has the stock 15" wheels/tires... would 1/2" spacers work (and look ok) until I can find wheels/tires? Thanks... and take it easy on a suv noob... :D |
Originally Posted by SureShot
(Post 260896)
(Post 260896)
(Post 260896)
Later, Doug |
Try this , pick up a set of 16X8 rims from a junk yard or place like that, kinda like the wheels from an Xtreme blazer like mine.. it will give a diff stance and you should not have any rubbing probs..
It's a 2wd, not a 4x4. 16x8's like a ZQ8 or Xtreme wheel will fit the same as the stock wheels, only an inch wider. You could do 275/60/15's on the rear if you want wider but same height as the front 235/70/15's.
Thanks for the input guys.
Next question, while in pepboys looking for some floor mats, I saw these wheels: http://www.pepboys.com/images/upload...ine_139_lg.jpg They have them in 15" x 8" for $50 roughly (8" wide wheels will work with stock tire sizes right?)... but I can't find the backspace and offset of these wheels... I can probably find it online with enough time, but what is the offset and backspacing on the stock 04 2wd 15" wheels? I think I read 6" backspacing and +42mm offset... does that sound correct? |
6" BS is for 4wd rims. I believe the 2wd's are 4.5" BS.
Not a bad looking rim really but what are the chances they are gonna have the 4.75 bolt pattern that we will need? Might even be tempted to jump the ditch to get a set for that price, even with the exchange rate
They are the 2nd wheel listed:
http://www.pepboys.com/tires_wheels/...chined_wheels/ They specifically say Blazers on their site... |
Hmm...if those are that cheap, I'd be tempted to get a set of those and keep the stock height tires and put some agressive AT's on em.
Exactly what I was thinin Zeeke98
