2wd rims on 4x4 question.
Old Jun 4, 2013 | 08:40 PM
Lil_J_357's Avatar
Lil_J_357 is on a distinguished road
Default 2wd rims on 4x4 question.
Has anyone put the 2wd swirl rims on a 4x4 blazer? If so did you have any problems? The rims are 15x7 5x4.75 and 4 or 3.75 backspacing. Im not sure if there will be any issues. I know it will make the wheel come out of the fender which is what i want. But besides that does anyone have any issues with them not fitting over the caliper or anything?
[IMG][/IMG]
Old Jun 4, 2013 | 08:47 PM
nunya's Avatar
nunya is on a distinguished road
I run/ran (they are now demoted to the winter set) only issue I had was some run on the bumper occasionally when turning and hitting a good bump, but that's a 31 clearance issue and happened with the correct 4x4 wheels
Old Jun 4, 2013 | 08:52 PM
Lil_J_357's Avatar
So since i have 28.9 ATs and im lifted 2 inchs.. I shouldn't have any issues? Do they mount right up??
Old Jun 4, 2013 | 08:53 PM
Lil_J_357's Avatar
Could you post a side pic view of the rims on your blazer? i am curious how much they stick out.. Right now i have a rim with almost like 7in backspacking its like 6 n a half. How much will it stick out? 2 inchs or so?
Old Jun 4, 2013 | 09:41 PM
nunya's Avatar
I do have a small spacer on the back to help even out the stupid narrower rear width. The tiny bit that hangs out ain't enough to warrant me bothering with flares (theres a 2 door with ZR2 flares and little steel wheels that are nowhere near wide enough to look 'in place' and that thing bothers me almost daily when I see it go by)
Attached Thumbnails 2wd rims on 4x4 question.-52957baf-92f2-4555-8df8-25620b56f01e-1417-00000264b1e24d33.jpg
Old Jun 13, 2013 | 11:56 AM
gibsonZr2's Avatar
gibsonZr2 is on a distinguished road
You can add spacers on the back and maybe some generic aftermarket flares thats might be smaller than the Zr2 flares and it will look more proportionate
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
purpleblazer95
Tires and Wheels
Mar 16, 2009 12:57 AM
1fastls1ss
Tires and Wheels
Aug 31, 2008 05:25 PM
a_tack
Tires and Wheels
Aug 12, 2007 12:08 PM
zero psi
Tires and Wheels
Apr 22, 2005 11:54 PM
