3/4in wheel spacers
Im looking for some 3/4in wheel spaces for the rear to even up the stance. I cant find any bolt on so what about these http://cgi.ebay.com/ebaymotors/ws/eB...&viewitem=. I would get two for each side. Im assuming i will also need longer studs. Also i plan on getting wheel adapters to fit 5x4.5 which are 1.5in wide. So the front will be out 1.5in and the rear will 2.25in
RE: 3/4in wheel spacers
You would definitely need longer studs to go out 3/4". Most spacers have another set of studs which is why they are most often 1.5" or wider.
Why not just get a 2.25" spacer that would adapt to the 5x4.5" pattern you are looking for and run that on the back. Would make more sense. |
i cant find any adapters that are that wide. Do you know where i could get some?
| All times are GMT -5. The time now is 08:38 PM. |
