-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   3 of the Same, 1 Different (https://blazerforum.com/forum/tires-wheels-13/3-same-1-different-29020/)
Xander2002 Mar 24, 2009 02:39 PM
When I bought my 2002 blazer it came with 4 235/70/15 (28x9.3/15) firestone tires, unfortunately about a month and a half ago my back right tire went flat so I out the spare on which is a 235/75/5 (18.9x9.3/5). ive now been driving around for about a month and half to 2 months. im pretty strapped for cash right now so thats my reason for not getting a new tire yet. I just want to no if driving around with a different size tire will cause any damage to any parts?
oisinirish Mar 24, 2009 03:20 PM
Everything I've heard is that two different sized tires will cause extra wear on your rear differential.
swartlkk Mar 24, 2009 07:17 PM
Put the larger tire on the front and do NOT use 4wd. But get a properly sized tire quickly. Some tire shops sell used tires that still have good tread on them. Check around, you may be able to get a decent tire to use for cheap.
WolfPack Mar 24, 2009 08:13 PM
ebay has good deals on some used tires :D
mdehoogh Mar 24, 2009 08:47 PM
Avoid burnouts with different sized tires, or else you'll end up like this dude
But as others have said, make sure you have the same sized wheel/tire on both ends of the same axle, 70's on the rear and 75's on the front and not 70's on right side and 75's on left side
TripleBlackBlazer Mar 24, 2009 10:11 PM
truth
Xander2002 Mar 25, 2009 10:20 AM
thanks for all the input guys, it really helped
oisinirish Mar 25, 2009 01:37 PM
Just a question on this subject. Will different size tires on the front affect braking and handling?
swartlkk Mar 25, 2009 01:40 PM
It will affect handling, but not really affect braking. It is just a lot safer for the driveline components so long as 4wd is not used.
