-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   30x9.5 or 255/70 on aftermarket 15's, 1st post! (https://blazerforum.com/forum/tires-wheels-13/30x9-5-255-70-aftermarket-15s-1st-post-61628/)
Benedict1337 08-10-2011 12:17 AM
if you go larger than the 30" tires you will rub without a lift. the 255's are about 29" tall about the same as your stock tire size other than they will be a little wider. My blazer was lifted with the same wheels as you and 31's and I still rubbed a little, nothing a little fender trimming won't fix
JohnDinca 10-13-2011 07:51 PM
My 98 came stock with 205/15/15 and there was more wheel well then wheel. I put 265/75/15 (31x10.5) and it looks great! However, I am surprised at how much power/acceleration I lost. I knew the larger tires would make a difference but not THIS much. Is it possible to get the original power back via PCM or Hypertech?
Benedict1337 10-13-2011 10:50 PM
you won't get your power back, but that will correct for your speedo error and recalibrate shifting points. The only way to see your "power" back is if you re-gear. You probably have 3.42 gears, you should have at least 3.73 gears with 31" tires
Scott Regier 12-07-2020 01:11 AM
Spacers
Can I have some of the money you're throwing around on tires? I'm poor.
