-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   31" or 32" tires..... help. (https://blazerforum.com/forum/tires-wheels-13/31-32-tires-help-29727/)
Shotgunn99 04-16-2009 11:06 PM
this will be my first set of large tires....
i want 31s or 32s to run on my stock 15" rims.
what brand would you recommend, for a fair price.
thanks.
Swain 04-16-2009 11:24 PM
Unless you go with 32/10.5or11.5/15 you will get an uneven wear pattern on stock rims, if you try 32/12.5/15 they will wear funny. That being said I would go for 32's because once you put the 31's on you will wish you did(I did anyways). Excellent all around tire would be BFG AT KO...I've ran most of the popular tires a/t tires on all of our work trucks through rough trails/mud/ice roads and I prefer the BFG's. Pump them up to 35psi and they will last a very long time with a proper alignment/routine rotation.
mikeinwi 04-17-2009 01:09 AM
in order to fit 31's on a non zr2 blazer ur gonna need atleast 2inches of lift and to run 32's youll need atleast 5inches of lift, just a lil FYI before you go out and buy tires that will be to big unless you already have a lift then buy away.
WolfPack 04-17-2009 02:50 AM
^^^^ YES.
Whats your current mod list? You need a long one to fit 32s.
bandidolenny 04-17-2009 03:41 AM
It would help us to know the year model and how much of a lift is on your Blazer. Is it a ZR2?
mikeinwi 04-17-2009 04:04 AM
after looking up his previous posts he has a 99 4dr 4wd with no suspension mods.
Shotgunn99 04-17-2009 10:59 PM
sorry heres the info,
1999 blazer 4dr 4wd automatic.
with 3in lift (new torsion keys in front and shackles in the back)
mikeinwi 04-17-2009 11:17 PM
with the 3inches of lift stick to the 31's and also keep an eye on ur cv angles that seems like alot of lift from new keys.
bandidolenny 04-17-2009 11:23 PM
I would go with 31"s. You will probably want to do a 2" body lift as well.
Shotgunn99 04-17-2009 11:33 PM
would it be smarter to go only 2ins in the front? and would that still have room for the 31s?
