33" tires
Can somebody help me out? 2003 with a 2" suspension and 2" body lift can i fit 33x12.5x15? or do i have to stick with a 32,31?
31's I would say..
I got a 3" body 1.5" susp and had to trim a fair bit in the front to clear... 33"s I could get away with a 10.5 maybe but would rub the frame was to bad with a 12.5 (have a set to try so will update when I get time to test fit) Keep in mind you will need to get a different offset wheel or you will be rubbing the frame pretty bad even with a 31... which will push your front tires past the fender a bit.. |
Chevelle, Pics?
i have 9 inches total lift with 33x12.5 and i have rubbing....needed a minor fender trim even with all that lift.
Originally Posted by warthogdriver
(Post 438832)
^^What they said^^
You could get away with 32's and a lot of trimming. But the backspacing would have to be about 5" on a 15x7 or 6" on a 15x8. At least that's my best guess. |
3" BL & 1.5" TB twist & the 32 x 11 rub on the front at full deflection with fender & bumper trimming when turning. But I have aftermarket flares & mud flaps on the front as well, just to keep the chit from covering the front windows. Check out my garage to see pics if you like.
<edit> I'm running 15 x 10 rock crawlers. |
rob44.... tire dimensions? and what size lift?
Originally Posted by TURBO
(Post 439034)
check my garage, I wouldn't reccommend you trim as much as I did, I would just stick with 31's....
My wheels are 15X7 with a 4.5" backspacing |
