4.5" bacespacing---wheels>thoughts?
I've got black procomp steel wheels 15" and 4.5" backspacing...
now, I'd like some tire size/brand suggestions. all I hear is 30" tires would work. but with the back spacing of these rims, I wanna know what's the largest I can go without problems. Stock 2 door 2000 LS Blazer |
with stock hgt i think 30 is the limit, and you most likely will rub
i did a 1.5 t-crank and 2" body lift to fit 31's....even now with alll the lift i have done 33's required trimming. |
3"BL 1.5"tb 32's with major trimming, and rub frame at full lock with 4.5" backspacing
30's to be on the safe side, 31's if you don't mind a little body re-working I would recommend buying a cheap 'test fit' set before forkin out the dough on a new set, heard lots of people having problems doin over a 30". the 4.5" backspacing will push your tires outwards 2" or so. |
very cool thanks guys :)
