4wd rims
will rims off a 4wd s10 fit a 2wd s10?
could not get a clear answer in the search. if not what could i do to get them to fit. |
RE: 4wd rims
The rims will fit
RE: 4wd rims
You will need to use spacers to get the proper backspacing. 2wd rims have ~4.5" BS and 4wd rims have ~6" BS.
RE: 4wd rims
Dumb Question:
Backspacing is from the interior or exterior of the rim when you measure it? |
RE: 4wd rims
https://www.rsracing.com/images/tech-wheelterms.gif
Rear Spacing = Back Spacing. The outside of the wheel is on the right and the inside is on the left Much more info HERE |
RE: 4wd rims
Thanks and nice pic. Im more of a visual guy so that helps. And Im sorry i looked at the question wrong too, i went the opposite way (which a guy i worked with before did, thats why i said it fit) from 2wd to 4wd. As Ricky would say "Two birds get stoned at once" (trailer park boys).
RE: 4wd rims
Whoops
I posted the wrong link. It just takes you to the image. I fixed the link so it should work now. It has a sweet backspace-to-offset conversion table... |
RE: 4wd rims
so they should fit? would i have to have spacers or could i just go about and justnot have them what would happin?
RE: 4wd rims
You would need some sort of 5lug to 6lug adapter (5x4.75 to 6x5.5) in order for them to fit. I've seen several 5lug-5lug adapters on ebay that would change the bolt pattern from 5x4.75 to 5x5.5 or something close to that but I've never seen any kind of 5lug-6lug adapter available...
An adapter would be a spacer, if you've ever seen a standard wheel spacer, just imagine that but with the lugs futher out (or in, depending on what kind of adapter it is) from the center... |
RE: 4wd rims
like swartlkk said, you need spacers to make them fit at the same place. 1.5" spacers are what you need. I got some for the rear of my truck for 30 bucks each at an autoparts.
