4x4 Spare different size
Hey Y'all,
I am putting P225/75R15 on my blazer, my previous tire size was a 235/75R15. My Question is, will a 235/75R15 work as a spare for the P225/75R15s or do I need to get a spare that's the same size as the tires I'm running? I have a 1996 Chevy S-10 4-door 4wd Blazer LS. Thanks for any help you can give me, Ken |
i would go ahead and get a new spare. your new tires are going to be shorter than your spare. i just dont know by how much. but on 4wd you dont want to mis-match tire sizes. its hard on the differentials because then they are constantly rotating at different speeds. another thing is when was the last time that you looked at the spare? it might be all weather checked and need to be replaced anyway. but you can talk to your tire guy and see how much difference it will be, or you could get a nice used tire to save a few bucks.
Temporary only. The 235/75R15 would work as a short time spare to get you home or to the garage to get the other tire repaired. The G80 limited slip probably wouldn't engage with the difference in tire size either.
actually I check on the spare quite often as the original fell off and I keep a spare in the back of the truck now.
I needed new tires and got a really good deal on four used tires already mounted on rims from a guy I know. I will start hunting for a used spare now thanks for the help! |
Originally Posted by Diaita
(Post 568919)
Not only will it affect the differentials and transfer case if you use the odd size, but another thing to keep in mind when changing tire size is speedometer, odometer, ABS and transmission shift points will all be adversely affected unless you have the PCM flashed. Add that to the price of the tires and see if it's still a good deal.
Originally Posted by Captain Hook
(Post 568936)
From what I've been reading there is not a whole lot of difference between a P225/75R15 and a 235/75R15 I believe its only the width of the tire that's affected not the height, am I wrong hear? |
Originally Posted by Ken87
(Post 568945)
OK sorry if this is a NewBe question but what is a "PCM Flash", who does it, how much does it usually cost, and how necessary is it?
(Post 568951)
It's about a 2% difference in tire diameter, which will mean that your speedometer will read around 2% faster than you're actually travelling. At 60mph actual speed your speedometer will read approximately 61-62mph. All this depends on how accurate your speedometer was with factory size tires, tire wear, and other things.
People run different tire sizes all the time without correcting their PCM. Ideally you should have your PCM flashed so that your truck's computer has the correct information to calculate shift points, how the ABS should act, and stuff like that. That being said, a 2% difference is quite small and I really doubt that it would have any major effect on your truck's performance. You will likely see a small reduction in your highway fuel economy.
