4x4 wheels on a 4x2
Can 4x4 wheels be adapted to fit on a 4x2? They have the same lug pattern but not the same offset. The 4x4 wheels won't fit onto the front. Is there a spacer or adapter I can buy?
Welcome to the forum.
Yes, I believe a 1.5 in spacer will yield the results you are looking for. If you have any more questions please post them in the proper area of the forum, as this area is just for introductions. :) |
Welcome from Michigan...
Thanks for the info, Thogert. Some labels, such as "Intros Only" make help newbies with posts.
Well, there is a 'sticky' thread at the top of the 'New Member' section titled:
Sticky: SECTION RULE -- The 'New Member Area' is Only for Introductions - No Help Requests Sorry if it wasn't clear enough. *Moved to 'Tires and Wheels'* |
