all stock tuckin 31
tire blew, out muddin in stock tires so i got some bfg all terrians there 31 with no lift in rubs pretty bad but i took out the nut in was rubbing on and hammerd in the fender and doesint run i wanted 30 becouse i no they would not rub but i needed tires, pics soon, got to go to work just a update.
RE: all stock tuckin 31
Did you get all 4 tires in 31? Or just replace the one that blew?
And you're not all stock running 31s if you hammered back the metal. That's the trade off...either lift it to clear 31s, or 'finesse' the fender. |
all 4 no lift no anything it does rub on frame at lock i only had to cut some inside fender on ther driver side but now im saveing up for a 3 inch body lift
There's no 3' BL for the 2nd gens. Only modifying a 1st gen 3'-er and fabbing your own bumper brackets.
And again, trimming/rubbing is not 'tuckin 31s all stock'. But, I'm glad you got the new tires! New tread is always exciting :D |
I was gonna say I have a b.l. and i still rub when cranked.
