american racing dished
Old Dec 16, 2010 | 09:49 AM
chidevildog's Avatar
chidevildog is on a distinguished road
great! i just ordered me a set of cooper's discover atr
30/9.50/15's can't wait
Old Dec 16, 2010 | 10:52 AM
BAM1369's Avatar
BAM1369 is on a distinguished road
Nice pickup on the wheels i was looking for a good deal on the same ones but came across ar23"s in stead and went with them.
My truck has the road noise i think you are talking about and when i was changing out my front brakes i noticed when i trun the hub by hand on the driver side it felt a little rough but not loose. Do you think its just the wheel berings or do i need to change the hole hub?
Old Dec 16, 2010 | 11:00 AM
ever since I got this truck it's been roaarrring/vibration hum while cruising in anyspeed.. I had an idea it was a wheel hub assembly.. Confirmed that 100% when I read some threads in this forum about it..
here's what i did:
I jacked up the front side. and with the wheels (bolted) i grab hold of the entire wheel and wiggled it up/down.. side to side.. I had a lot of play in both direction.. (driver side) the passenger side had no play..
I have an 4x4, IIRC 2wheel are different perhaps you can only change the "bearing" instead of the whole hub assembly.. the "guru's" can confirm this..
Old Dec 16, 2010 | 11:04 AM
BAM1369's Avatar
I dont have any play in mine, so im guessing its ok to assume its just the berings?
Old Dec 16, 2010 | 11:17 AM
don't take my word for it this is just my guess.. if you don't have any play on either hub.. i think it's something else? I did read a thread in this forum about some guy thought his hub assembly was fubar.. but he changed it and the noise was still there.. and later he found the culprit.. it was bad cv.. not quite sure if it was the upper or the lower.. i'll send you the link if i find it..
Old Dec 16, 2010 | 12:29 PM
rob44_90's Avatar
rob44_90 is on a distinguished road
Do you mean it was a bad ball joint?? There are no upper or lower CVs, just axle CVs and a drive-shaft CV on our trucks.
Old Dec 16, 2010 | 01:02 PM
yes i stand corrected
BlackBastard
May 19, 2010 12:20 AM
spectorscoob
Tires and Wheels
Dec 21, 2008 04:15 PM
dieseladdict90
Tires and Wheels
Sep 15, 2008 11:04 PM
brunosrk
Tires and Wheels
Nov 12, 2007 06:10 AM
flyinbrad
Tires and Wheels
Jan 28, 2007 07:05 PM
