Anyone with irocs and rear spacers...
Can anyone please tell me the size of spacers they are using in the rear to even out there Irocs on the non ZR2 models. I keep hearing 1.25 or 1.5 spacers. Is on eavh side or? Someone told me 1/2 these widths also?Totally lost..Getting tires on my finally powder coated irocs and need spacers to get them on..Some please help...
16" Irocs with staggered offsets? or The common 15" Z28 wheels?
With even backspacing all around, it doesn't matter what kind of wheels, you'll need 1.25" spacers. 1.5" will work too. Blaz runs Z28 wheels with spacers on the back https://blazerforum.com/forum/builds...-blazer-75972/ |
I have the 15 inch version.. Thanks..I will check the link you gave me ..I appreciate it much..
By my measurements 1.25" spacers make it even with the front. That's what I used. Many people also use 1.5" spacers. Really the 1/2" difference is not likely to be noticeable.
Thanks El_Beautor now is that putting a 1.25 spacer on each side? Someone told me awhile back that the size should be half per each side..I figured this to make no sense but just want to be sure.Thanks..
1.25 each side, so 2.5 overall
Thanks alot guys!
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1404605710 I ordered these supposed to have by Monday am hoping they are what I needed..
Those are what you need. Remember to make sure that the lug studs don't stick out past the spacer. Some people have had to shorten the studs. Just an FYI.
Looks like you got the hub centric ones, definitely what you want. I got 1.5" but kinda wish I had gone with 1.25, although I doubt it makes much difference.
