Biggest tires I can run?
Hi everyone I'm just now begining my customization of my blazer and would like some feedback. I have a 2001 Blazer LS 2-door 4WD with 31 x 10.5's now. My plan is to get a 2" body lift, and a 2" suspension lift as well. I was wondering if anyone knew about the largerest tires i could run with the lifts.I'm hoping to run 33's but would like some feedback. Thanks.
RE: Biggest tires I can run?
better question: How are you running 31x10.50s with none of the afore mentioned lifts. Do you have a ZR2?
I know that is a good question. I don't have a zr2 either its just the LS model. The tires are just Michelin X Radial LT tires 31 x 10.50. I don't experience any rubbing or problemswith these either.
Interesting...normally you need 2' of lift to run 31x10.50s...
If you have a stock suspensioned (non-zr2) blazer, this thead will answer your questions: Lift Kit List If you scroll down past the listing of lifts, there's tire sizes that will fit with each amount of lift. |
Alright thanks alot I appreicate it. And i actually ran into a guy the other day with almost the same truck as mine, except it was the ZR2 model and he was running 35" tires, but with alottt of trimming and a 2" body lift. I hope to get 33's in with minimal trimming with the4" of total lift.And congrats on the Ride of the Month your blazer is dirty.
