-   Tires and Wheels (https://blazerforum.com/forum/tires-wheels-13/)
-   -   black 18" z06 wheels on a jimmy (https://blazerforum.com/forum/tires-wheels-13/black-18-z06-wheels-jimmy-37069/)
jwayne13 11-17-2009 10:57 PM
i bought a set of 18" z06 wheels. what size tire should i use to give it a nice look? (i plan on lowering my jimmy 2/3 or 3/3)
old skool luvr 11-17-2009 11:17 PM
why not go with the size on the Z06?
Sisk 11-18-2009 06:39 AM
33x10.5 :icon_lol:.
I agree with Chris though. Why not go with a stock size for the Z06's?
oktain 11-18-2009 10:59 AM
Personally, I'd try and keep the overall stock diameter of the wheels, that way you're speedo will be just as accurate as before.
Oh... Pics or it didn't happen!
okvortec 11-18-2009 11:01 AM
x2
If you do get a different size tire and do not re-calibrate the speedo, not only will your speed be off but your mileage will be off on the odo vs actual mileage as well.
jwayne13 11-18-2009 04:05 PM
i dont wanna put on a too low of a pro becasue of where i live the roads are horrible
old skool luvr 11-18-2009 04:48 PM
Originally Posted by okvortec (Post 264880)
x2
and your ABS too. although i personally care more about my speedo/mileage being acurate (i just unplug my ABS anyways).
i can understand jwayne, about the rough roads, but unless you're able to have your computer "adjusted" for the different OD, you're gonna run into a whole mess of problems with the above mentioned, plus your TCM will read everything improper, which will cause the lock-up to act up (didn't intend to rhyme there) and who knows what else.
what size is the factory Z06 tire? i know the fronts are different from the rears, so give me both.
jwayne13 11-18-2009 05:41 PM
im using all front tires, all 18s and the size is 275/40/18
cbr995 11-18-2009 08:25 PM
wanna see pics!
Those rims will look great, btw.
How much were they? If you don't mind me askin'.
old skool luvr 11-18-2009 11:54 PM
your closest tire size (to the stock truck size of 235/75/15) is going to be 275/50/18. this gives you a OD of 28.82 inches (compared to 28.87 inches), making it out by 0.18% the Z06's tire of 275/40/18 is only 26.66 inches, out by 7.66% more than the 3% maximum to maintain speedo/ABS function.
you can also try 245/55/18, OD of 28.61 inches, out by 0.91%, or a 245/60/18, OD of 29.57 inches, out by 2.37%-but your speedo will show slower than actual speed by 2.5 mph, not good.
go to a tire shop, look at the sizes i've thrown @ you, and see what you like. a 50 series side wall, on that wide of a tire is going to be pretty tall, so it may be to your liking.
hope this helped.
